CS_Agent
Mischa88
I need to find my sim cards tracking number.
hairbag1
@Mischa88
with uncertain Canada Post, best is to get a Public Mobile sim yourself. As well as the above suggestions, if there's a Mobile Klinik in your area...they usually have the sim cards available there also. Check the Yellow Pages or better yet...Gogle.
CSA_PM
Customer Support Agent
Hi there. I sent you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
@Mischa88  SIM card can take as long as 3 weeks to arrive typically thou you should see within 10 bussinesss days , but if you need one sooner consider picking one up from Koodo store or Telus store can also buy from Amazon also . And it’s good to have spare SIM card in case you loose or damage yours and or to give to frend or family memeber to join public mobile using your referral code and then win win for both of you in that case . But as far as tracking public mobile doesn’t have tracking number for SIM cards unfortunately
hi @Mischa88
sim cards are sent by Canada Post , without tracking
But you can check with PM support on the status
you can submit  ticket by direct message:
