CS_Agent
ashikayy
Hi there. Can I get a CS_agent to get in contact with me??
Chalupa_Batman
Hello @ashikayy
Public Mobile is a self serve service. These forums are your first point of contact to get any help if another community member can share their wisdom with you. However, if you feel it's above their knowledge, you yourself can contact a CS Agent. If you have the ability to log in, this is the proper way to contact them.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
@ashikayy  Sorry they won’t contact you , instead you must engage them for help
you can use the orange chat bubble bottom right of screen  or send  a  private message   To CS_Agent
hi @ashikayy
there is a chance Community can help if you want to share,
but if it is account related, then yes, check with PM support agent.  Only way to get them to help is to submit ticket.
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
