@CS_Agent
FelixFox
Hello! Trying to transfer number and messed it up. The eSIM changed when trying to reply 'Yes' and now it's been over 90 minutes, so I guess I need to retry it. Please help!
1 REPLY 1
@FelixFox
can you at least make outgoing calls with the eSIM?
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
