Buying a sim card
dnewf
Hi all can someone tell me if walmart still sells PM sim cards?
9 REPLIES 9
Scoman20
Yes, they do but that might vary store to store
Got mine online but would have done Walmart had I known
https://public-mobile.myshopify.com/cart/add?id=5876039041
@jrboodoosinghOr if you live close to the growing number of official Public Mobile booths, you get the SIM card free, might get some bonuses + your $10 referral. Just make sure your SIM card is tested working and has been provisioned propertly before you leave though.
Pulk
They should still sell them, although you can also use Amazon, which offers fast shipping rates, or select kiosks that also carry them. Best of luck and welcome to Public Mobile 🙂
jrboodoosingh
After trying two different Walmarts and coming out with no SIM because the cell phone person was “on a break” and the regular electronics guy “couldn’t” pass me a SIM card I decided to get it through Amazon. If you have a referral code you get back the $10 you paid.
goldilock
Amazon now sells Public Mobile sim cards.
ShawnC13
Reading between the lines here a bit.  Yes they do sell them but are you asking if they will just sell the sim without activation?  That is an unknown some of the Walmarts do and some don't.
geopublic
@dnewf  Click here to find the store nearest you.
wetcoaster
Call your closest store's electronic department to find out if they have them in stock?
Triguy
Here is a link for the store locator.
https://www.publicmobile.ca/en/on/store-locator
