Buying a Pre-Owned Phone QUESTION
roseauto
Are pre-owned phones unlocked?
and Do I need a public mobile plan to be able to buy a pre-owned phone?
Thanks.
2 REPLIES 2
@roseauto
about the Black Friday with a $30 bill credit for existing customer or new customer,to use it same email in your account to getting, but if you not have any account you won't getting,
and take advantage of a 1-year warranty. Plus, if you're not happy in the first 30 days, return it for a refund.
and Save more this Black Friday with a $30 bill credit when you purchase. between November 16-30th, and you’ll receive a $30 bill credit.....
Purchase Phone (publicmobile.ca).. Good Luck.
if you have account with public mobile the credit will be applied to the account that is associated to the email address that you use to place the order, is eligible for existing customer and new customer,
this credit one time $30 will be applied on January 5th 2022.
@roseauto
No need any plan,
anyone can buy it.
all devices phones are unlocked.
