11-27-2020 05:58 AM - edited 01-05-2022 04:16 PM
I am looking for a phone in public mobile to buy and pay monthly??
11-30-2020 02:48 PM
Your options are to buy an unlocked phone and go with Public Mobile, or to buy a subsidized phone (pay monthly contract/Tab/etc) with another carrier.
Public Mobile now sells a small selection of refurbed phones. If you buy a phone anywhere else then you must also buy a ($10) SIM card for Public Mobile. If you buy a used or refurbed phone then you must make sure it's unlocked (not carrier-locked) to use it on Public Mobile (test it with Public Mobile SIM card before buying, if you can). If you buy a phone online then you must make sure it's radio-compatible with Canadian/USA networks.
11-27-2020 09:06 AM
@Samiraso If that is the case then Koodo or Telus would be a better fit for you.
11-27-2020 07:40 AM
You have options to buy online and pay in installments (4 being best.) for a phone.
https://www.factorydirect.ca/apple-iphone-8-64gb-unlocked-smartphone-red
https://www.factorydirect.ca/samsung-galaxy-j3-5-qc-16gb-unlcked-android-51-smrtphnrb
https://www.factorydirect.ca/samsung-galaxy-s9-64gb-unlocked-android-smartphone-grey
11-27-2020 06:07 AM - edited 11-27-2020 06:07 AM
Unfortunately not possible with public mobile. They just starting selling used phones and you pay up front. If you like the Telus brand and network then try Koodo. They offer what you're looking for. You'd have to switch companies tho.
