08-14-2021 10:31 AM - edited 01-06-2022 03:07 AM
I have an iPhone 8 with a glass back is it able to be repaired? if so would it be under warranty?
Phones
08-14-2021 05:51 PM
@Frankileng if you are paying for the repair, you can check with local mobile shops. Or if you ask PM, they will ask you to visit MobileKlinik as it is owned by Telus.
08-14-2021 01:26 PM
This unlikely to be covered under warranty but is certainly repairable. If it just the back, glasses that is cracked the average price of the repair is between $50 to $99. As mentioned you may have device insurance if you purchased the phone with usually a premium credit card such as RBC's infinite avion visa card. Check your card's insurance details.
08-14-2021 12:06 PM
I doubt any manufacturer will cover broken backs or screens.
It will be considered user's fault as it has nothing to do with product malfunction.
If you bought your phone with credit card you might look into CC coverage. They might cover damages or loss/theft.
08-14-2021 11:49 AM
A. Rocken glass screen will not be covered under any warranty from PM.
Many malls I have seen have mobile repair shops. What city are you in. I'm sure members will be happy to find you a place to get it fixed.
08-14-2021 11:43 AM - edited 08-14-2021 11:43 AM
08-14-2021 10:40 AM - edited 08-14-2021 10:47 AM
Was your phone purchased from PM ?
If your mobile phone is damaged due to neglect or abuse, it will not be covered under the 1-year Certified Pre-Owned warranty.Some examples or physical damage include:
- Broken LCD screen
- Broken flip
- Damage to housing
- Broken charging port
- Warped internal components
- Bent / cracked main board
Check https://mobileklinik.ca or if there is no mobilelink location in your area then contact a Telus store.
https://www.publicmobile.ca/en/on/get-help/articles/phone-warranty-returns-repairs
