Bought the 200 mins long distance...and it's not showing up in my account
ArisingPeace
I did a bit of a search, and I don't have 8$ in "Available Funds"
and the long distance add-on isn't showing up in the add-on section
I bought the add-on on August 9th
ArisingPeace
sent a pm
@ArisingPeace Did you check on the overview page under Add-on section? If you see your data but not the LD add-on, send a private message to the Moderator_Team with your ph# and account#. They will get back to you shortly.
ArisingPeace
it must be a glitch.....money was taken from my card....and I have a 0$ balance
I can't even see the option to purchase that add-on anymore
neatooo
buying an add-on is a two step process. you buy it first, which gets money from your card. then you buy it again using the loaded money. Did you do that?
