Bought e-sim by mistake
Alexis22
Hi there, I bought a subscription with an e-sim. Realize now I don't want the e-sim as I would like to purchase a sim card tomorrow in person and need my current purchase refunded, bought a phone as a gift and also need to gift a physical sim card as well.
thanks so much!!
7 REPLIES 7
@Alexis22 it is a requirement to use the app to complete part 2 of the activation, the phone number part.  You need the app even for Physical sim.  Again, just delete it after successful activation
Alexis22
It wont let me log into my account, says I have to download the app, I don't want anything to do with the app
@Alexis22 even with physical sim card, you need the app to complete the second part of the activation. Once activation is completed, you can delete it.
If you cannot download from app store due to region issue, sideload it
Alexis22
Do not want to download app, want physical sim card
DennyCrane
Wasn't the e-sim free? In any case you can get a physical sim. I wouldn't recommend purchasing from PM directly though, as they have challenges fulfilling which results in some pretty significant delays. You'd be better off trying to find one at a local Telus or Koodo store, or purchasing from Amazon.
Alexis22
I also don't want to start my subscription today necessarily , its a gift not needed for a couple days.
@Alexis22  No worries get a new SIM card and sim  card swap the number on your my account like this
SIM  SWAPPING  profile tabs
Note only do this on lap top or computer/ not mobile device
adding you can see if support may credit your account for cost of esim since it was a honest accident please check with support
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
