09-04-2016 11:00 AM - edited 01-04-2022 01:00 PM
Hello! I don't have access to an IMEI for the phone I'm planning to get (Blu Vivo 5) and would like to know if it's compatable with PM. I found the phone on amazon.com and .ca. The .com one works out to be cheaper even with the exchange rate.The American one seems to work on a little less network frequencies than the Canadian one.
PM works on:
American version:
Canadian version:
I checked online and it says the phone is compatable with PM except on 2G. I just want to be sure it'll work before I send money on it.
Thanks
09-05-2016 06:37 PM
Please keep us posted, @deepg82, though you should not have any problems.
09-05-2016 06:23 PM
Thanks! I guess I'll just try activating it
09-05-2016 05:00 PM
@deepg82 it's possible that both are the same and one of the listings (.ca or .com) is incorrect. Regardless, the only difference appears to be LTE bands 12 and 17. I would go with the cheaper options, as you won't benefit much from those bands on PM.
09-04-2016 12:04 PM - edited 09-04-2016 12:05 PM
Voila from willmyphonework.net: 3G yes, LTE sporadically as only 1 of the bands. BUT you'll only know for sure when you install a PM SIM.
