11-24-2023 02:54 AM
For How long are the Black Friday deals on? If I switch to 30G, 4G for a $34 deal today, would the new plan start when my previous subscribed plan would end or right away?
11-24-2023 09:09 AM
@Pashmak All good things come to an end. There is no guarantee that the current black Friday deals will last a long time. If you want risk it and wait for cyber Monday, maybe PM will offer a different deal then? But like I said, there are no guarantees. If you'd rather not take a risk, you can take advantage of the current deals now but choose to have it switch over on your next renewal date. That's the best of both worlds... It buys you time and allows you to select the sure thing.
11-24-2023 05:51 AM
@Pashmak When you select change plan you will be given two options, change now or change on renewal. If you change now you will be charged immediately and not be pro-rated for what was remaining of the old plan so, as @Hollister said, make sure to select change on renewal. You can do that now to make sure you get the plan you want while it is still there, no need to wait. I usually then take a screenshot showing the plan change just in case there's a glitch at renewal time.
11-24-2023 03:21 AM
Only Public Mobile knows when these deals will end. If changing plans choose change on next renewal date. Do not choose an immediate plan change, because you will receive no credit for your current plan.
