Billing cycle
03-29-2024 12:44 PM
Trying to find a way to change my billing cycle payment from 30 days to 90 days. Without changing my existing subscription.
Payment
03-29-2024 11:58 PM - edited 03-29-2024 11:59 PM
@BKNS27 wrote:You can login to your PM app and it will specify the range of your subscription dates.
Eg: Current Subscription Cycle: Mar 22 - Apr 21.
Ironically, the Self Serve site shows the wrong dates for all customers. In the above example, that's adctually 31 days when the plan only lasts for 30 days.
03-29-2024 12:57 PM - edited 03-29-2024 12:59 PM
03-29-2024 12:57 PM
You would have to find a plan witch renews every 90 days. No other way to change it.
03-29-2024 12:56 PM
on the down side...if you're on a 90 day plan but decide to upgrade to a different plan OR if you decide to leave PM..you have to plan that strategically so as to minimize loses in current plan. As far as I can figure...the 30 day plans have the least risk.
03-29-2024 12:56 PM
I am not on the $55 plan. I understand. Thank you for your reply.
Resolved !
03-29-2024 12:47 PM
Hi, the only way to change cycle to 90 days is if it's available for 90 days. Currently only tithe $55 dollar plan has 90 days. Is that the plan you are on?
If not, you cannot.
