11-09-2021 08:29 AM - edited 01-04-2022 05:14 AM
Hello I am set up for automatic deposit for public mobile payments however recently it has told me that my service is not active and therefore I need to make a payment. Why is this occurring? please help.
Thanks.
11-09-2021 11:24 AM
go sign in to Self-Serve, to review your account,
1. Click on Payment
2. Make a Payment
3. one Time Payment
4. you will see your Amount Due:$$
5. Payment Type: selected other ( Enter the desired payment amount )
6. how much you see at Amount Due:$ ! you will do manually enter Amount:$$ + $1 extra
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and if still not fix it follow this,
what is mean for Rebooting the phone means to turn off your phone about 2 minutes and turn it back on.
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to they can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck.....
11-09-2021 08:49 AM
@yodahe01 Autopay might have failed. It happened sometimes
try to make a manual payment from My Account, at Payment tab, select One Time payment
First try to pay by the Amount Due and see if it works (if it fails, try to select Other and manually enter your Plan Amount +$1 )
Once payment gone through, if there is a button "Reactive current plan", click on it.
then logoff from My Account and Reboot your phone and you should be good.
11-09-2021 08:42 AM
Autopay sometimes fails. You could purchase a voucher and call 611 or use recharge.com or ding.com but there is a service charge. Some people make a manual top up payment before their renewal date as a backup in case autopay fails.
11-09-2021 08:33 AM
Unfortunately, autopay sometime does fail. Has this happened more than once?
Try to manually load funds equivalent to your month's fee and then your plan should become activate again. If manually load funds does not work, the set up with your credit card is incorrect and you may need to re-enter the information again.
11-09-2021 08:32 AM - edited 11-09-2021 08:34 AM
@yodahe01 wrote:Hello I am set up for automatic deposit for public mobile payments however recently it has told me that my service is not active and therefore I need to make a payment. Why is this occurring? please help.
Thanks.
Is your service still working?
If yes, there is nothing to worry about. The plan is in the process of renewal and money will be debited from your Available funds/Credit card. Sometimes it could be running late but eventually, everything will return to normal.
If you've lost service, that means Autopay has failed. Log into your account and check if there is enough funds there to cover the cost of the plan. If No, top up via your credit /debit card (or a voucher) and click on the Reactivate button if you see one. If Yes, then try to Suspend then Resume service to reactivate the account.
