Billed twice same minute
wgordy
Hi, I recently updated to the 4g plan with 4gb of data. However, I was billed for $39.38 and $43.31 back to back. I choose to have the new plan take effect immediately which makes sense, but didn't expect two charges. Can someone explain what the first charge is for? I don't see that there's a plan charge change fee anywhere.
@wgordy yes , when you click Change Plan now, PM will start a new plan and will charge immediately.  Remaining days on the old plan will be wasted.
did you make plan change on day 1 of your old plan?
You can open a ticket with PM support and explain what happened, hopefully they will agree to do something :
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
dabr
@wgordy   Yes, unfortunately, you will be charged again the full amount of a new plan change if you opt to Change Now/Immediately.  It's always recommended to choose Change at Next Renewal option precisely because PM is prepaid and doesn't prorate/refund.
However, if the plan change was done on the same day as your renewal, perhaps ask for a goodwill gesture from customer support for an honest mistake although there's no guarantees they will offer any account credit.
You can submit a ticket via chatbot here:  https://www.publicmobile.ca/en/on/get-help
Metal1967
@wgordy  that’s something only cs agent could fix/ look into. Send them a message..
