Bill
Bayboy45
I paid my bill. But still can't make calls need help.
2 REPLIES 2
hi @Bayboy45
Check if PM took the money for renewal.   Using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in), and check if account shows active with a cycle date ends in August
Reboot the phone and try again.  if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
slusagm
Try reboot phone.  Sometimes, it takes 5+minutes and a device reboot is needed
if still unable to make calls or no data, ask PM to help. Submit a ticket
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
