10-10-2021 11:02 AM - edited 01-06-2022 03:31 AM
10-10-2021 03:17 PM
Did you activate in-store? If so you have to finish setting up your self serve account. Click on the box with lines in it at the top right corner of your screen and sign into the account set up on the right side and follow the prompts.
If you activated online yourself then log in to your self serve account on the left. Your username is the email you signed up with and the password you chose at the same time.
10-10-2021 01:44 PM
Login to my account. first tab of overview will tell you all.
for further details click on corresponding tab or links.
10-10-2021 12:57 PM
Log in to your account and you will see all details
10-10-2021 11:28 AM - edited 10-10-2021 01:50 PM
That's a very short description of the issue.
Luckily, the title said it all.
Edit: I must admit, I fell for the spoiler.
10-10-2021
11:14 AM
10-10-2021
08:46 PM
computergeek541
@Manpreet98 wrote:Hi,
You can find out some details of your account when you call 611 from your device.
Log into your Self Serve account...if you have not created one yet, you can do that here: https://selfserve.publicmobile.ca/self-registration/
to see your current DATA amounts, and Minutes used (if you are on a limited Minutes plan).
10-10-2021
11:06 AM
10-10-2021
08:45 PM
computergeek541
What are you trying to look for?
Login to My Account and you will see your upcoming Amount Due and due date.
Transaction History on My Account would should you what you have paid in the last couple months
10-10-2021 11:05 AM
Welcome to the community. Any specific concerns or questions about balance?
Any positive balance in your account will be used for next payment date.
