10-15-2025 05:20 PM
Is there someone who has recently been to the Los Cabos area and has used the Cda/USA/Mex plan? We need to be sure the plan is problem free and includes roaming. Any other concerns you might have? Many thanks.
12-05-2025 11:02 AM
10-15-2025 06:46 PM
we usually spend several weeks in Mazatlan and can say the the PM Cdn/US/Mx plans works just great. You'll be able to utilize service from Telcel, AT&T or Movistar...might be others but that's the 3 we've seen.
You must make sure you enable Roaming in the cellphone settings to be able to us data...otherwise; no pasa nada amigo.
10-15-2025 05:23 PM
It will work. Make sure you turn on Roaming Mobile Data on the phone and connected to Telcel or AT&T there
