08-01-2023 11:13 AM
08-01-2023 12:02 PM
08-01-2023 11:24 AM
08-01-2023 11:22 AM
Thanks
08-01-2023 11:21 AM
Thanks
08-01-2023 11:20 AM
You can freely change plan and it wont' affect your current rewards, also confirmed by Community Manager here:
https://productioncommunity.publicmobile.ca/t5/Announcements/FAQ-amp-Troubleshooting/td-p/986594
Will I be moved to the new rewards program if I change my plan?
Changing your plan won’t automatically transfer you to our new Public Points rewards program. If you’re currently on our legacy rewards program, you will continue to stay on it. However, we encourage you to explore Public Points, as it opens up even more opportunities for savings.
08-01-2023 11:15 AM
You keep the old rewards. You keep all your freebie add-ons. You might lose repeating items in the promobox area.
08-01-2023 11:14 AM
@Eddyo wrote:Do I keep my existing awards if I change plans
Yes, you will keep your rewards after changing plans. This includes loyalty, autopay, and refer-a-friend rewards.
