01-18-2022 12:23 PM
My dad's phone has been disabled because the AutoPay (which hint hint means that money is taken from the credit card automatically, Public Mobile FYI) didn't work. Please resolve!
01-18-2022 01:21 PM
@Georgecc wrote:My dad's phone has been disabled because the AutoPay (which hint hint means that money is taken from the credit card automatically, Public Mobile FYI) didn't work. Please resolve!
Check if there were any changes in the address/phone number or a new card (different CVV)
If no, try topping up your account with $1 and check it is working manually just autopay is not.
Try removing the card and logout and login again in incognito mode and add the card again and test again topping up $1.
If all above is working and it simply missed the payment then send a direct msg to CS_Agent to get more details on this.
01-18-2022 12:46 PM
sometime the autopay failed..do you can check your credit card is not expires.
i suggest you close all Browser and do clear cache and cookies for any Browser,
and try open one Browser incognito mode,
or try it for a different Browser and open incognito mode,
how to open Browser incognito mode visit Here link,
how to clear cache and cookies and History visit Here link,
and use a Browser from your computer,is better
use Browser microsoft edge or chrome latest version
and just make sure your Browser is up to date update
sometime is the Browser is not update is give a issue.
how to update your Browser visit Here link,
and Restart your computer, is will help a lot,
and log in and re-entered your credit details,
just make sure your credit card number and your address match the same,
sometime your typing but is a one word or letter or number is a wrong or missing just make sure for it.
How To Update or Remove Your Payment
Follow these steps:
1. sign in to Self-Serve. Once signed in,
2. click on the ‘Payment’ tab,
then scroll to the bottom of the page and select ‘Manage my card’.
you will have the option to either select ‘Replace this card’, or ‘Remove this card’.
You will need to review and confirm this change to your account,
after you Add your credit card go back,
and if can't fix it you need To Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent,
Good Luck.
01-18-2022 12:31 PM
01-18-2022 12:31 PM - edited 01-18-2022 12:33 PM
@Georgecc Can you login to My Account? Confirm if the account is Suspended
Make a manual payment to get your service back first
login to my Account and use the payment tab ((https://selfserve.publicmobile.ca/Overview/payment/Make-a-Payment/)), and click One time Payment
First try to make a payment using Amount Due.
If there is any error paying that way, try again using "Other" and enter the Plan Amount +$1 extra
If payment successfully processed with one the 2 ways above, check if there is a button Reactivate current plan, click on it
Then logoff My Account and reboot your phone
01-18-2022 12:26 PM
@Georgecc : Autopay sometimes fails. You'll need to log in or use 611 or 18554public with your 4 digit PIN and manually pay enough to get your balance up to your plan cost. Don't use Amount due on the site.
