04-06-2019 04:56 PM - edited 01-05-2022 07:06 AM
I have been using autopay for several months now, and I haven't had the discount applied to my account. I do have two referals that are being applied, but not autopay.
04-28-2019 06:44 PM
Yes, thank you.
The MOD just removed and added the autopay feature and I see it now in my rewards page. I also noticed I was only getting 500 Mb of data, not the extra 500 Mb bonus for auto pay. I think this fixed that problem as well.
04-16-2019 01:12 PM
@Sapper, did this get fixed for you? It's been about a week since we last heard from you.
04-08-2019 02:03 PM
@Sapper, are you a former Legacy/Pioneer member? I recall there being an issue with the AutoPay might not work, and the suggestion was to remove AutoPay, and sign up for it again.
04-08-2019 01:48 PM
I just sent a message.
04-08-2019 01:37 PM
@Sapper wrote:My Overview says I'm currently registered for Dynamic Autopay. But each month I get the follwoing text:
"Congrats! Rewards have been applied to your account: $2 friend referrals, $0 AutoPay, $0 Community, $0 Loyalty"
Did you write to the moderator? They can see what's in your account but not us. We are customer like you.
04-08-2019 01:34 PM
04-07-2019 05:31 PM
@Sapper, take a look at your payment history, your should see it in there.
What is your plan cost according to the website? Your plan cost, - $4, and that new value is multiplied by the tax amount. I think you’re seeing a difference because of the tax, ans taxes are not displayed in the interface.
04-06-2019 10:41 PM
@Sapper wrote:I have been using autopay for several months now, and I haven't had the discount applied to my account. I do have two referals that are being applied, but not autopay.
Autopay reward should show in rewards as soon as autopay is enabled. Is it shown in your rewards? It gets added to balance before renewal. Did you add credit card but not turn on autopay?
04-06-2019 05:00 PM
You can't see the 2$ for AUTOPAY in the rewards section in the first page fo your self serve account BUT you can see your credit card information? If it's your case you need to reach the moderator here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and explain what happened with details. They will help you. Waiting time is few hours to 2 days.
