09-15-2019 05:59 PM - edited 01-05-2022 07:06 AM
Hello beautiful people ,
Just want to know if I purchase a U.S. Roaming add-on will it automatically take the place of my regular data? So would I keep my regular data option on or off for it to work? I've never purchased U.S. Roaming or data abroad before.
Also, can I purchase it while in the U.S. using wifi?
Thanks,
Niya
Joining Public
09-16-2019 09:37 AM - edited 09-16-2019 09:37 AM
@Niya Luckily at PM there's no possible way for your regular data service to be used when roaming. Once the system recognizes you're not on their network (i.e. Telus/PM network), the data service automatically won't work, so you don't need to make any settings changes on your phone. So the only features that will work while you're in the U.S. are the roaming features that you purchase. I used the U.S. roaming a few times last year, once your 10 day expiry comes up then yes try and get access to Wifi and then re-add the roaming feature again.
09-15-2019 11:21 PM - edited 09-15-2019 11:24 PM
@Korth wrote:Expires 10 days after activation, not 10 days after purchase. You can purchase as many as you like and keep them sitting (dormant) in your account for as long as you like.
But you can only activate one US Talk, one US Text, and one US Data component at a time... which starts the 10 day expiry timer... apparently the system won't allow you to activate an Add-on component while another of the same type is already active (I haven't confirmed this firsthand).
All add-ons, upon purchase, activate immediately, including U.S. roaming add-ons. U.S. roaming add-ons cannot be banked for later usage. They will all expire within 10 calendar days of purchase (the day of purchase counts as a full day no matter when in day the purchase was made).
09-15-2019 10:18 PM
09-15-2019 06:23 PM
09-15-2019 06:03 PM
It can only be used in the US and does not effect your regular plan data. You can purchase it in the US. Keep it mind it expires 10 days after purchase.
09-15-2019 06:03 PM
Both will be available to you simultaneously. If your in Canada it will use your Canadian data. If you are in the us it will use your us data.
Remember to enable roaming while your in the us and look for an at&t or T-Mobile tower to connect to.
