10-10-2019 01:29 PM - edited 01-05-2022 07:30 AM
Is there an automatic top-up option in the event you run out of minutes or data before the end of billing cycle?
10-10-2019 03:31 PM
@Robertx wrote:That works for me. Basically, they are as good as money in the bank.
Not really, you can't cash out if you don't use it but yeah, you can keep add-on until used up.
10-10-2019 01:50 PM
10-10-2019 01:47 PM - edited 10-10-2019 01:48 PM
@Robertx wrote:Are add-ons a one time cost or do they continue monthly?
They are a one time purchase without expiry and roll over until you use up all the features of your add-ons. Except for the US roaming add-ons which are time limited to 10 days.
10-10-2019 01:46 PM - edited 10-10-2019 01:47 PM
@RobertxCost for each add on are per individual add on. Not monthly.
10-10-2019 01:45 PM
10-10-2019 01:36 PM
@Robertx wrote:Is there an automatic top-up option in the event you run out of minutes or data before the end of billing cycle?
Data also rolls over until you've used them up.
10-10-2019 01:31 PM - edited 10-10-2019 01:32 PM
No but you can buy Talk or Data Add-ons to prevent loss of service.
These Add-ons will not expire and stay on your account until the minutes or data are fully consumed.
10-10-2019 01:31 PM - edited 10-10-2019 01:39 PM
No sorry you have to purchase add-on manually
You can do it before you run out, the unused protion would roll into the next cycle, it will not be used until all the minutes of the cycle are consumed. So if you are finding yourself little bit short every month, they could take you long way.
If you are running out in the middle of the cycle by accident or temporary change of habits you can ask moderators to review you early.
If you are finding yourself short more than a week most of the time you should consider upgrading
