01-06-2023 12:36 PM
Hello,
I had one of the original 90 day plans with Autopay renewal. In January 2023 I changed to a 30 day plan with a better data plan. The Autopay took the old 90 amount instead of a 30 day amount. Although I now have a 2 plus month credit, I would like the correct Autopay amounts debited moving forward. The Public Mobile logic when changing data plans does not reflect the change in renewal amounts.
Please advise.
01-25-2023 04:28 AM - edited 01-25-2023 04:29 AM
Thank you! I was wondering about this and here you are nearly 3 weeks ago with the answer to my theoretical question. So unlike the autopay glitch that suspends you that a manual top up payment will avoid it still occurred. $10 isn't the end of the world but a 90 day payment can be for some on a tight budget. That leaves two options:
01-06-2023 01:38 PM - edited 01-06-2023 01:45 PM
I had a similar thing happen with one of my managed accounts on Dec. 29. The plan was set to change from the $25 plan to the $15 plan. As I do for all my managed accounts, I made a manual payment a few days before the 29th to ensure there was $15 in available funds. But then on the 29th, it took out an additional Auto payment of $10. Now there is $10 in available funds. I assume this is the reverse of the Auto pay glitch when someone moves to a higher priced plan, but the Auto pay takes out the lower amount, resulting in the account suspending.
*** edited to add payment history ***
01-06-2023 12:46 PM
There was another customer asking about this last night. I would watch carefully for your next renewal but otherwise leave it there for your next few renewals. I wouldn't bother support until you see an incorrect charge either next renewal or early Apr.
01-06-2023 12:43 PM
Yes that is correct, new plan and $rate applied, but previous amount deducted leaving future credits.
01-06-2023 12:41 PM
So you went from a 90 day plan to a 30 day plan, but the amount charged was the 90 day amount? Did you verify that your plan has changed correctly and that you are currently on a 30 day plan. If your plan did switch correctly and it put the excess charged funds into your AVAILABLE FUNDS I would create a trouble ticket to speak with a CSA to make sure that once those credits are used up you will only be charged the correct 30 day amount.
I also just switched from 90 to 30 day plan on Jan 1 and everything went smoothly for myself
