AutoPay Issue.
se2020
Hi There,
It has been two months in a row that the AutoPay option has not charging from my account, and I got to pay it manually. Could someone fixing this issue please.
Thanks,
17 REPLIES 17
@se2020 wrote:
I said Two months in a row, and not two times. Connection and credit card entry is not an issue. Now removed AutoPay and Re-registered AutoPay and see the next month charge.
I heard you say 2 months in a row....did I say something different?
With your new card give it a test and add $1.
But can you make a small manual payment with the registered card you have? Just toggling autopay off and on won't test anything.
se2020
@dabr @LurganIeUk @Anonymous @Triguy
Thanks for all the comments.
I got to be offline now hoping all having a wonderful week end.
dabr
@se2020 wrote:
Sorry not sure how to do that.
1- press reply
2- then ???
3- Post button
@se2020   Yes press reply then use the @ key on your keyboard to see the names of other users and click the one you want to address.
se2020
1- press reply
2- then ???
3- Post button
se2020
dabr
@se2020   Just a heads up that you can use the @ key and a list of the usernames in this thread will appear, then you can click the username you are responding to.  Makes it a little easier to follow the conversation. 😊
se2020
Sure I am.
se2020
To be honest, I rarely login unless I have an issue. PM should take this as a feedback.
Two times in a row....something is wrong big time. I wonder if it is on your side? Incorrect entry of card or your CC company is rejecting charges? But I guess not if you have used your online set up to do a manual top up. I had it happen to me a few times on Telus, but years apart.
I would suggest the hybrid method to avoid failure now and in the future and you will still receive the $2 reward.
You're not the first and you definitely won't be the last. You came here for the rates...not champagne and caviar. 🙂
dabr
@se2020 wrote:
Hi There,
I have noticed that the PM site login is pretty slow compare to general site access on the net. I' m sure not the only one complaining this.
@se2020    Yes it seems to be very slow right now.  I'm having the same problem, the pages are taking a while to load.  Also another frequent issue with PM unfortunately.  It usually gets fixed after a short interval.
se2020
Hi There,
 @se2020 : But of course no one should be "forced' to workaround the payment system. Can you do a manual payment from that card? Like a dollar? Just to see that it works manually.
Are you paying for multiple accounts on the same night?
Failing that then remove what you have and try to add it again. Make sure the address matches that of the billing address. No space in the postal code or drop the last digit. Maybe do everything in caps. Only try once or twice each say hour otherwise it might think a fraud is happening and lock you out.
If you can re-register a card and do the small manual payment then be sure to turn on autopay again.
dabr
@se2020 wrote:
Hi There,
Thanks,
@se2020    There seem to be more than the usual number of autopay failures lately going by the number of times this issue has been posted over the last few weeks.
I would also submit a ticket to moderators so that they are aware this is happening more often.  You can submit a ticket via chatbot and follow prompts here:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
se2020
Thanks for your prompt reply.
I will do that and see how thing go.
Triguy
Autopay sometimes fails.  Try removing and add back your credit card.  Some customers keep a balance in their account to covers plan costs as a backup.
