12-25-2022 12:19 PM
For many months I have 3 phones on auto-pay with the same card. Auto-pay had worked without issue. Its the same credit card with >$20 000 available balance. Phones have been disconnected for non-payment, it still says auto-pay is set up, and manual payments do not go through.
12-25-2022 12:24 PM
@simpasimp so, all three phones are now suspended and no service?
do they all renew on the same day? and same plan amount? not a good idea as credit card might see those charges and thought they are duplicated charges and might decline it
did you try to use Incognito mode and login to My Account and try to pay again?
If that fail , ty to pay amount due via *611, but you will need your 4 digits PIN. If you have forgotten the 4 digits pin, you can reset it yourself at My Account
If you tried and still unable to pay, open ticket with PM support and have them to sort it out for you
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
12-25-2022 12:22 PM
Are you saying at all 3 phones autopay failed?
When was your renewal date?
Does your account show as Active?
Did you try one of these below to manually pay and check account status?
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
