02-19-2021 12:22 PM - edited 01-06-2022 02:08 AM
02-19-2021 12:36 PM
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
02-19-2021 12:33 PM
@harrycasual wrote:I want to be set up on auto pay. How do I do it?
@harrycasual follow the instruction by @HALIMACS above. If you cannot access the link, here it is...
To log in self serve account, click this
https://selfserve.publicmobile.ca/
Welcome to Public Mobile
RosieR
02-19-2021 12:28 PM - edited 02-19-2021 12:33 PM
@harrycasual To set up AutoPay, sign in to your self serve account select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
02-19-2021 12:23 PM - edited 02-19-2021 12:24 PM
Like this, @harrycasual
Set up AutoPay (publicmobile.ca)
You're wise to want to do this, you'll save $2 every 30-day cycle just for being registered for auto-pay.
Welcome to Public Mobile!
