11-24-2016 07:17 AM - edited 01-05-2022 12:53 AM
11-24-2016 07:13 PM
11-24-2016 11:32 AM
I don't know if Twitter is "better" - there were some people claiming to have had success that seemed faster through that avenue.
Not having clear insight into how the backend system works and how the issues are queued up for resolution make it very difficult to trust that your message has been received and will be addressed.
I sent one message during the promo window and it took the moderators 7 days to respond. If you haven't seen anything after 1 week I would put in a follow up message.
11-24-2016 09:18 AM
11-24-2016 07:45 AM
You can't re-port your number. I wouldn't call Bell since they still think they own your number and I wouldn't want to risk loosing it. You could try reaching out over twitter to see if that helps get some attention for your issue. How long ago did you send the private messages?
11-24-2016 07:29 AM
