10-10-2017 09:36 PM - edited 01-05-2022 03:23 AM
Hello all!!
I just thought I would pop on, while using my data, because you see, I split an internet bill and connection with my neighbours two floors above me, and it’s not been working for the last 3 hours!
They’re not home at the moment, but for the first time in 3+ years, I am sitting pretty with my lovely 4GBs of data and not a worry.
Thanks again PM. You’re rocking my world 👌🏻😆
10-11-2017 12:08 PM
I mentioned on another thread that I ran into a similar pinch when the lightning zapped my modem, router, etc. the 12GBs was used up, but it was just enough to carry me for the critical web surfing. It sure is nice to have - this is also why I don't mind paying a few extra bucks for a few extra GBs that I wouldn't use otherwise.
10-11-2017 06:09 AM
10-11-2017 12:49 AM
Makes you think how reliant we are on having an internet connection nowadays. Being disconnected gives you the withdrawal jitters within minutes.
Seriously though, yes. Having a good data plan really helps in those situations.
10-11-2017 12:24 AM
In a pinch 4 gigs of data is a life saver. In real world application as a home internet replacement, not so much. My home internet usage is measured in tb, not gb.
10-11-2017 12:11 AM
Enjoy. 🙂
10-10-2017 11:33 PM
Nice!
Isn't it great that you can use all 12GB if you want?
