02-17-2019 06:24 PM - edited 01-05-2022 03:23 AM
I would like to change my plan. Can I get someone to assist me?
02-17-2019 07:45 PM
Happy that everything went well...
02-17-2019 07:42 PM
It’s been a long time since I changed my plan, and wasn’t able to back then. Plan changed all is good.Thanks guys.
02-17-2019 06:49 PM
@Mike-m wrote:I would like to change my plan. Can I get someone to assist me?
If you got set up in a store, then have you created your account log in yet?
If not then you'll need to do that first. Go to the upper right My Account link and on the right side click on the Create Account button.
Then read this.
There you go will13am. I was writing a whole long hand-holding thing and thought about your favourite knowledge base articles.
02-17-2019 06:40 PM
02-17-2019 06:29 PM
And here you can choose a new one...https://www.publicmobile.ca/en/bc/plans....
02-17-2019 06:28 PM
You can change it by yourself in your self serve account... click on plans/add-on..you can see your actual plan and you can click on CHANGE.. @Mike-m can you see it?
