03-23-2021 08:07 AM - edited 01-06-2022 02:22 AM
all of the apps on my phone stopped working, messages, messenger, amazon, etc. What can I do to fix this?
03-23-2021 02:07 PM
Yes, to everyone reading about this issue, DO NOT factory reset your phone. That is not necessary. Just follow the guidance posted in the thread. For some, uninstalling Android Webview updates did the trick, but that's ultimately a workaround. You'll want to update this app and any others to the latest version, going forward.
03-23-2021 01:55 PM
@totalUser wrote:Mine is disabled for months now (when i read your message i remember temporarily disabling it and i totally forgot about it i was gone enable it right after) and i still hit the bump last night. I thought my phone is gone, it just happened that i temporarily put loads of stuff to transfer for somebody. I've read and saw this can happen if you used up your space, so i removed everything but that didn't help. I was certain my drive is going until i noticed that bunch of stuff just updated. As google was crashing the most i just uninstalled all the Google updates and everything is smooth since then. I also noticed the message that Google go is available, I'm considering replacing it permanently with Google go.
@totalUser Yeah, my thoughts were also that it was my phone that was the problem last night knowing it's getting a little old now. The only things working on it last night was actually the phone and Whatsapp.
Tried some troubleshooting including the ever recommended rebooting and reinstalling the SIM which obviously didn't work. Started to read online that it might be related to a Google app affecting lots of other people and that they were working on a fix, so left it alone until this morning hoping it was sorted out overnight. No such luck and after reading another couple of articles this morning, tried one that suggested to uninstall the updates from the Android Web System which did the trick.
A huge relief that it wasn't the phone after all!!
03-23-2021 01:12 PM
03-23-2021 11:42 AM
@Donna21 @mh1983 is right this is related to a Google app. I've had the same problem since yesterday evening. Just uninstall all updates from Android System Webview app (under application manager), you might need to okay the request to replace the app with a factory stock version which is what I did. Then reboot the phone . That fixed everything for me.
03-23-2021 09:52 AM
Same problem here, but i got them to work again
Don't reset your phone Google update is the issue.
I cleared all cache and uninstalled updates to Google. I'll wait for the next update and try then.
Another option would be to try Google go instead and disable google. I'll try that on the tablet if it gets the same issue after update and I'll report back
03-23-2021 09:25 AM
@Donna21 I think your recent update may have corrupted your operating system. you may have to factory reset your device
03-23-2021 09:09 AM
This is a global issue that Google has addressed.
https://www.theverge.com/2021/3/22/22345696/google-android-apps-crashing-fix-system-webview
Basically, do any app updates that you have. Reboot the phone for good measure. That should get you back up and running.
03-23-2021 09:01 AM - edited 03-23-2021 09:02 AM
@Donna21 : Please address some of the troubleshooting questions being asked so we can help narrow down where the problem is.
Calls in/out?
Texts in/out? (maybe even texts in/out with either wifi or mobile data on)
Internet browsing on mobile data?
Internet browsing on wifi?
Edit: Try the SIM in another phone as well if you have one available.
03-23-2021 08:44 AM
Galaxyj3prime
I turned phone off for awhile
Still telling me that apps stopped working
Phone has been updated
03-23-2021 08:32 AM
Do all other calling features work? Talk, text, BOTH in and out?
If they do, and you still show Data under your self-serve, try the troubleshooting items, leading to Moderator contact if none get you going:
To contact a moderator, there are 2 methods:
03-23-2021 08:27 AM
Still lots of data
03-23-2021 08:16 AM
If you still HAVE data left, can you check that all other calling functions work (calling and texting BOTH in and out)
If not, try these troubleshooter items:
03-23-2021 08:16 AM
what kind of phone is yours?
did you try reboot your phone?
any difference between using Wifi and Data?
Also, did you try updating all your Apps? and see if any update to your phone?
03-23-2021 08:09 AM
Check your data allotment under your Data and Add-On's section
If it's not shown under that category, it's all gone.
Try a Wi-Fi zone instead.
