Apps Not Working or Updating
Billy2
Most of my apps including google play store are not working. It says I'm offline even though the wifi is connected. How do I fix this?
9 REPLIES 9
srlawren
@Billy2 any luck?
srlawren
@Billy2 here's a troubleshooting guide from Google:  https://support.google.com/googleplay/answer/7513003?hl=en
@Billy2 so you are connected to wifi. It doesn't sound like you using data, right?
If you are not able to connect to apps using wifi, try:
  • restarting your phone
  • are there settings where you can clear cache of apps, do that if so
  • uninstall one of the apps, then reinstall it. Does it work then?
@Billy2   do you have iPhone or Android?
You checked My Account and confirmed that you still have data ?  is there a line about data on the Overview page, My Data & Add-ons Section?
I was digging around and did find that one could actually log out of the Play store (well, I found a sign out button). Maybe if one does that it disables other apps. But I really don't know. I didn't try it.
Billy2
Can't have been logged out of google cause google pictures is still working.
dust2dust
I'm not sure how but I wonder if the device got somehow logged out of Google?
Billy2
Most apps say offline except for a few.
Hi @Billy2   does it work when you are on Wifi?  Check that first
if it does not work on Wifi as well, it will be a device issue
if it works on Wifi, then make sure your Mobile data is enabled.  And make sure you didn't set a data limit
Also, some people set  mobile data restriction on app like Google Play store
