Anyone help pls
Sadiyaali
How can I know my account number?It’s argent and also I want to call an argent to ask my account number any one know?
@Sadiyaali
Are you porting out of PM?
Sadiyaali
Thank you but the problem is that I can’t even log in into my account
@Sadiyaali you can get it by logging into My Account, then go to Profile page
https://myaccount.publicmobile.ca/en/account/my-profilehttps://myaccount.publicmobile.ca/en/account/my-profile
Sadiyaali
I can’t even log in into my account that’s the problem I have
Chalupa_Batman
Hi @Sadiyaali
How to find my account number
Log into your account and go to Profile on the left hand side.
Then on your right hand side you’ll see this…
Click on the eye to see your account number.
Created by Chalupa Batman
Phil_Adelphus
@Sadiyaali   Are you unable to log in to your account?  If you can log in your account number is shown there.  If you still need an agent send a private message using this link
An agent will reply at your community inbox, envelope top right or tap your avatar if no envelope.
