Any points to redeem below 10?
Huan
Before I have 8 dollars deduct every month. It’s really good and it’s why I sticked on public mobile more than 3years. But the new point system I can’t use my points because I can’t find any redeem option less than 10 dollars. And I should do it every time manually.   I prefer to use the previous automatically reward system.
9 REPLIES 9
Sansan
Ok glad you found it. At least you know your options and how to redeem/where.
They do change this up from time to time so keeping checking.
Huan
Thank you. I only need bill credit currently. Never have chance to use these add on with current plan.
Sansan
https://myrewards.publicmobile.ca/en/bc/?code=zPvFtNdqtgZ2W_JK4K7Vm_1w7Lc&iss=https%3A%2F%2Fauth.tel...
Try this. Change categories  to ALL. Yes bill credits is min $15. But there are other stuff too.
Huan
Under bill checks in category, only one option, can’t scroll down. Would you kindly share your screen?
@Huan
15 points is the minimum number of points to redeem $15. You will also get an email reminding you that you have 15 points to redeem.
I just redeemed mine the other day.
Sansan
@Huan did you bring up the catalog? Click on Browse Catalog.  Scroll up, load more, scroll, load more. Tons of stuff.
Huan
there’s only one option for 15 points under category “ bill credits “ . Can’t find any add-on.
maybe your public mobile is smart than mine.
Sansan
@Huan for bill credit the minimum is 15 points for $15.00 off. But you can do add-ons for starting at 5 points. You have to browse the catalog.
Sign into your account and click My Rewards tab to view.
missorange
yes, there is no choice to switch back to the previous reward system, public mobile lost all benefit to stay with it, such as no auto pay reward $2, and loyal reward ($10 vs $60) per year.
