07-15-2021 10:31 AM - edited 01-06-2022 02:48 AM
07-15-2021 12:23 PM
Too thick or too wide?
It is hard to see how to punch out the nano size. It only fits in one way.
07-15-2021 12:00 PM
It should be nano SIM size. Make sure the gold side is facing up.
07-15-2021 11:59 AM - edited 07-15-2021 12:00 PM
@Rilea...once you've selected the correct sim size...it should just nest neatly in the tray. The corner of the sim is clipped so will only fit one way.
07-15-2021 11:53 AM
I have made it the smallest, but it is too thick to go on tray. Do I trim to size of hole?
07-15-2021 10:43 AM
Use a straightened out paper clip or a SIM card tray pin ejector. Find the Sim tray usually in right side (if facing) phone. Then push pin into hole..press fairly hard. It should come out. If phone is in a case....remove the case.
07-15-2021 10:41 AM
07-15-2021 10:38 AM - edited 07-15-2021 10:40 AM
@Rilea...what exactly, is your question ?
To get the sim in your i7, you pop open the sim tray and install sim.
