Any experience at 2300 Yonge st. (yonge and eglinton centre)
itimjob
I use Rogers (iPhone),  barely  able to get the signal in this mall sams as FIDO And WIND.
Wondering how about PM ?
I work in this mall and think ing to switch over PM.
Any idea?
Many Thanks in advance 🙂
fibi200329
I was at yonge and eglinton centre over the weekend and did not experience any signal issues. Although I was just using data/text and not voice. The signal should be the same as Telus/Koodo. Hope that helps!
CaNuCk07
If you really want to check and be sure, you could sign up for a 10 day plan, if u like it then you can port your number over, if not then you, spent a $20 to check. The dollar saving with PM is well worth it!
kav2001c
@itimjob if it is a mall why not check out the Telus / Bell kiosks in the area? Pretend to shop for service, and borrow the demo SIM to check signal strength & speed.
The Source (owned by Bell) will give you a great signal test
http://www.yongeeglintoncentre.com/StoreDetail.aspx?StoreId=15808
Luddite
Sorry, i'm out in Mississauga but how about finding a colleague using Telus/Koodo/Public Mobile. All three use the same network in Toronto.
If you got your phone from Rogers it must be unlocked to connect to Public Mobile.
