05-03-2021 03:55 PM - edited 01-06-2022 01:57 AM
Malware alert: https://www.bbc.com/news/technology-56859091
05-03-2021 11:34 PM
@will13am wrote:Be sure to disable app installation from unknown sources in the security settings.
That's good advice since an app installed from an apk could have came from anywhere. I would say that only installed from Play Store isn't a guarnatee of security either, as there have been apps that got removed from the Store because of tasks that some apps were disocvered to preform.
05-03-2021 10:29 PM
05-03-2021 09:25 PM
05-03-2021 09:03 PM - edited 05-03-2021 09:05 PM
Meh, these articles really unfairly paint Android with a bad brush. It's not Android, it's the user who screws up. These sort of scams are usually targeting the type of people who end up using Apple iOS anyway, as Apple users tend to be the less tech. savvy group. I mean let's be honest, iPhones tend to be the phone your grandparents, soccer moms, etc use because they don't really need to know anything about setting the device up.
05-03-2021 04:12 PM - edited 05-03-2021 04:13 PM
Thanks for the info.. 👍
the Spammers and hackers really everywhere these days
05-03-2021 04:11 PM
Right. Learn not to click on 'offers' or 'amazing apps' or similar.
NOBODY on this planet loves you so much (family, maybe??) to give you free stuff or free money.
05-03-2021 04:09 PM
Again, it is up to USER to be diligent. All this crap will NOT install by themselves! User has to click on link or button or whatnot.
Just train your brain NOT to command your hand or finger to click/touch certain stuff...
Same as you would not 'touch' very hot object. Simple 😉
05-03-2021 04:01 PM
Thank you for your information!
