10-11-2024 11:31 AM
Hi. I have an Android phone with a PM 4g LTE plan, the other is also an Android with some Freedom Mobile plan. We're both going to be in the US at the same time. 1. Can I send and receive texts with the Freedom person without doing anything? 2. If both of us have RCS and Roaming turned on, would that be sufficient? 3. Do I need the talk/text add-on to send/receive texts with the other Android.? I did some searching but couldn't find a definitive answer. Thank You.
Other
10-11-2024 07:36 PM
Thank you all for the replies. I wish I could pick everyone as ‘Accept as Solution”. I decided on installing WhatsApp and will try and convince the Freedom Mobile user to do the same.
10-11-2024 11:39 AM - edited 10-11-2024 11:40 AM
Yes you need USA Add-on for you to call, text and have data. You will also need roaming enabled but you may have to connect to AT&T or T-Mobile network. Also enable VoLTE for calling.
If you and your other party have WhatsApp or TextNow app. You can call and text for free on wifi.
If your friend have Canada, USA & Mexico plan. They don’t need Add-on.
10-11-2024 11:36 AM
HI @Bacsi
yes, if both have RCS and Roaming turned on and both have roaming mobile data, it will work
but if you don't have roaming mobile data, it will only work when you have wifi
10-11-2024 11:35 AM
you'd need a 15 Day US roaming add-on with text to be able to text each other. Either that or a currently offered US/Canada plan. Another option is to use WhatsApp to message each other using local wifi or separately purchased local data.
10-11-2024 11:33 AM - edited 10-11-2024 11:34 AM
@Bacsi Yes you can and yes you will need US add on to do so . Unless you have CAN/US plan that has roaming built into it
