Admin
Tezz
Please help.
I need a rep or someone to contact me ... or give me a 12 digit code. As mine went through but not a **bleep** thing happened.
You need to gave people LEGIT PEOPLE working this online thing. Not a robot with questions already answered.
Please contact me.
treefrog
@Tezz
Try the resources in this thread for more information on vouchers. You can also ask customer support if your voucher has been redeemed or not?
https://productioncommunity.publicmobile.ca/t5/Get-Support/Can-t-Make-a-Payment-or-Update-Your-Card-...
Hi @Tezz it's is a voucher problem??
Did you try to login My account with Incognito/Private/Secret mode to confirm?
If you don't see it showing in Available fund and not on Payment history there,  submit ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
Yummy
Real, live people DO HELP if you ask them nicely. NEVER had ANY issue with agents when asked them for assistance.
It is VERY EASY to create a ticket and agents do respond promptly.
To Contact CSA-agent there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
pmva
@Tezz
It sounds like you'll need to contact an online agent to help with you with this issue.  We're all users like you so hopefully an agent can help you with this issue.  I'm not sure what 12 digit code you're requiring.
You can contact an agent using the chatbot.  Type "agent" and click contact us to go through the wizard.
If for some reason they don't respond to the ticket, you can try to send an email directly to the CS Agent here.
Here is a KB article about contact the CS Agent.
@Tezz
Some vouchers may take up to 24 hours to active your account.
You can contact a CS_Agent by private messaging on the envelope icon above.
