Additional data add-on purchased but not accessible
Ginnettie
A couple weeks ago I was on vacation and ended up using my 3 months worth of data allotment. I went and I purchased add-on data of 1 GB, I can see the add-on has been purchased and it shows as 0.5% used and I show a thousand megabytes left over but no matter what I do I still have no data. Does anybody have any advice? Sorry if this has been answered somewhere, I can't seem to find the answer.
7 REPLIES 7
Ginnettie
Well this is embarrassing. I thought refreshing the page was the same as refreshing the feed for data usage but it was not. I had signed in and out of this page several times thinking that it should refresh every time, but it didn't. I looked for this spinner icon you were referring to and finally pressed the right one lol. And lo and behold the 1 gb that I thought I had left was no longer there. How embarrassing. Lesson learned. Thank you for your help!
Ginnettie
Tried, no luck 😞
Ginnettie
Nope
Ginnettie
Originally I thought I used it all up but when looking at my account, it shows I have unused data available
darlicious
@Ginnettie
Do you have your data limiter enabled in your phone?
dust2dust
Click on the little spinner refresh icons lower down or use private mode. The numbers should update. maybe you used up all the 1gb too.
Remember
@Ginnettie
use different browser,open incognito mode,clear cache,cookie, try Login
still not work,  open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot.
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response from CS_Agent.
