Paid for extra data but didn't receive it.
Thebikeguy
I was running out of data so I purchased additional data on April 7/24. It was charged to my credit card and I got a confirming email but today while running errands, I ran out of data. How do I fix this?
Thebikeguy
No it wasn't the US add-on. I have a ticket and will have to deal with CS. Thanks for your help.
Thebikeguy
I have already had a ticket issued and will work it out with a technician. This was a one off situation so no need to switch plans. Thank you for your reply.
HALIMACS
@Thebikeguy
You can:
  1. purchase another block of data.
  2. request to switch plans on an immediate basis to start a new cycle with a higher data allotment - you can do this on your self-serve account.
  3. request the customer support staff to renew your CURRENT plan early to start the cycle over.
The choice is really yours - if you choose to go with option 3, you'll need a customer support agent.
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us,  or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
HI @Thebikeguy
did you buy the wrong data? maybe you got the US roaming data?
Login My Account using Incognito/private/secret mode on the browser and check.
If you got the wrong one, or really cannot find the one you bought, ask CS agent to check.  Submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
