08-24-2019 03:07 PM - edited 01-05-2022 08:40 AM
Hi,
I want to make a payment, or add for autopay my visa debit. (Which i've used before to pay i'm sure.)
When punching in my name and card number and that info the field for the expiry date is a drop down menu. You can't type over it, you have to select from the choices in the menu. And my year... 2025 is not listed among the options ... i tried the closest one 2024 but it would not process.
Can anyone explain or tell me what i'm doing wrong?
Many Thanks,
Jason.
My card is 2025 which is not listed here.
08-24-2019 03:16 PM
Thanks for the info. I'll msg them right away. Cheers.
08-24-2019 03:12 PM
@Jas0n in the meantime if you have another card maybe use that or buy a voucher for payment
08-24-2019 03:10 PM - edited 08-24-2019 03:11 PM
@Jas0n hi yes they are having issues with that you need to contact a moderator to get them to do it for you click here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
