07-27-2022 11:35 AM
If I update my Plan do I lose my add-ons. For Example: I have 2gbs free from a bonus offer. Would I lose it if I changed my plan?
Thanks
07-27-2022 11:47 AM
It depends, as far as I know the add-ons should remain with a plan change if you paid for it. As it's a promotional add-on it should also remain.
07-27-2022 11:46 AM
HI @aghussey Yes, for that particular one, you will be able to keep it until all used up
enjoy the new plan
07-27-2022 11:45 AM
Thank you. My bonus GB was from Xmas, therefore, if I update my plan I will keep those 2GB. 🙂 Great
07-27-2022 11:42 AM
@aghussey if it is the 2GB free bonus offer from the Christmas , then you got to keep it
But if it is the 2G Bonus from activation, then with a plan change, you will loss it as stated in the original terms
For other add-on you paid for yourself, and rewards like loyalty, Autopay and friends, you will be keeping those
