Add-ons
08-17-2019 12:28 PM - edited 01-05-2022 06:27 AM
08-21-2019 03:11 AM
You can try to contact the moderator and explain your situation to them. Hopefully they understand and can help you out a bit.
Usually these plans are non refundable and if you have no luck with the moderators, hopefully not. You can try to manually select a carrier in your settings and try to connect to a US carrier like AT&T or T-mobile. That will probably only work if you're close enough to the US to pick up a signal.
But hopefully the moderators are able to help you out in some kind of way.
Best if luck 🙂
08-17-2019 01:06 PM
If you message the moderators very soon after getting the plan and have not used it much, I think the moderators might be able to credit you the money. You can message them using the link given by one of the community members
08-17-2019 12:30 PM
@FL2 contact a moderator for that https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-17-2019 12:30 PM
Generally, there are no refunds for prepaid plans.
However, if you explain your situation to moderator, they might be understanding and able to help. Expect 1-2 day wait.
Send a private message to moderator through the following link :
