Add ons
Janice58
I purchased the us add on data and talk.  Talk isn't working
14 REPLIES 14
@Janice58 wrote:
Galaxy A50.  It can't find another network.  Crazy thing it did work for I day
HI @Janice58
A50 is not VoLTE compatible with PM and I am not sure if it is VoLTE compatible with A&T and T-Mobile
but as I said, try to connect to T-Mobile and set 3G Only as network mode.  Go to T-Mobile store for help
If the phone still cannot connect to T-Mobile, then stay with AT&T and use VoIP app to make calls. download TextNow or Fongo and make and receive calls using the app
Janice58
@Janice58 wrote:
I have it on automatic.  And only AT & T shows up
HI @Janice58
that would be the problem, you need to try T-Mobile.  So, you tried to change network and set network to manual and let the phone shows what network it sees?
What brand and model is your phone?
anther trick is bring your phone to a T-Mobile kiosk and ask them to help you to connect to T-Mobile
Janice58
Janice58
How do I do that?  I have an android.  Mobile networks has data which is set to roaming on
Network mode is set at Ltd/Wcdma/GSM auto connect
Network AT & T
@Janice58 wrote:
I am in the US and bought it for that reason. Does it have a limited amount of minutes?
HI @Janice58
yes, unlimited inbound and outbound calls to US and Canada
@Janice58  It’s unlimited mins and text just the data is limited to 3GB
Janice58
HI @Janice58
as explained, try T-Mobile
Start with leaving the network mode as Automatic, if still not work, then change network mode to 2G if the option is there
@Janice58  Try connecting to T mobile instead see if that works
Janice58
It is connected to AT&T lite
hi @Janice58
at least data work?
for voice, what phone do you have ? you might be able to use VoLTE.  you can try connect both AT&T and T-Mobile and see if volte work
if not, connect manually to T-Mobile and test calls first.  If still not works, while you are at T-Mobile, change network mode to 2G and try again
if nothing works, then you will need to use VoIP app as workaround.  Best to choose TextNow. It allows you to make calls using the app on Wifi or mobile data
When you're in Canada, does VoLTE work?  If it doesn't, you might not be able to use voice services while in the U.S.
@Janice58  Out you phone to 4G/LTE and connect to T mobile or AT&T if still issue with voice try phone set to 2G and connect only to T mobile
