11-09-2016 10:02 AM - edited 01-04-2022 06:09 PM
11-09-2016 10:30 AM
11-09-2016 10:09 AM - edited 11-09-2016 10:10 AM
You can't roam in the US yet but they are going to announce that soon.
If you are in BC, you can call any number in BC and that will not be charged to the LD add-on. Any incoming calls and any outgoing calls outside of BC while you are there will be taken from the LD add-on(assuming your home province is normally not BC).
11-09-2016 10:05 AM - edited 11-09-2016 10:06 AM
Hi,
At the moment, PM does not let you roam in the US or anywhere outside of Canada.
However, if you are in BC, and your home # is on Quebec, then yes, your outgoing and incoming calls will use your LD minutes.
See here for complete details.
Cheers,
Neil
11-09-2016 10:05 AM
Hey to answer part of your question, as of right now, there is no US roaming with PM, but its in the pipeline for maybe this month. Check out hte link below.
