12-03-2017 04:53 PM - edited 01-04-2022 03:03 PM
Hello,
I just activated public mobile today with $22 plan. i thought that it includes texting aswell but it is not. how can i add texting to it.
Thanks
12-03-2017 07:08 PM
Only data can be purchased as an addon. Talk and text must be part of the base plan in order to have the service.
12-03-2017 05:02 PM - edited 12-03-2017 05:03 PM
There's no add-on to get for texting. You can send a private message to the moderators asking them to make the change to your plan. You just have to pay the difference for adding texting. Since you just started they should be able to make this change. Just know that typically this is not possible to change your plan mid-term as PM is a pre-paid service.
Send them a private message using this link: @CS_Agent@, provide them with your name, account number and an explanation of the issue and they will be able to look into the matter for you.
