Add on data
LilMissVix142
What do i doo if add on data is not working?
Perfect! @LilMissVix142
yeah.. it was suggested on my first post.   And happy that it works !!!
LilMissVix142
Oof~ how have I not done that.🤦‍♀️
Fixed~ thanks
@LilMissVix142  try reboot your phone first
Also, confirm on your phone if yiu enabled mobile data limit and disable it
@LilMissVix142
If you were charged for the Add-on data. Just reboot your phone by powering it off then back on.
LilMissVix142
Just data
@LilMissVix142 what kind of addon?  roaming? or data?
try reboot the phone first.  Use Incognito mode to login to My Account to confirm if the addon there
