05-03-2023 09:55 PM - last edited on 05-03-2023 10:49 PM by computergeek541
I try to log in and it says "Password/Email wrong"
I try changing password and nothing gets sent to my E-Mail. I just want to update my billing info.
Needing the website instead of some app is a real pain.
05-03-2023 09:58 PM
@RavenTree check the spam box , maybe it is there. Or try other possible email address you might have used
if nothing work, please open ticket with PM support
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
05-03-2023 09:57 PM
Check your junk or spam folders on your e-mail.
Also, when trying to access self serve, if available, use a desktop or laptop device in incognito or private tab. Tends to be less error prone around here...
