Add on data first
AKVR28
Hi
I have a 5gb data which expires in 31 days. Is there anyway to get PM use the add on data first before using my subscription data? Thanks
2 REPLIES 2
Sansan
@AKVR28 since your own data is used first you have to finish it quickly for the add -on to kick in. What I do, is to turn my wifi off even when I'm home. My phone is always on data. I watch tons of movies and YouTube videos. If your phone is on wifi, you will never use your own data so you won't be able to take advantage of the bonus.
sorry @AKVR28 the system is set up to use you regular data first before the loyalty bonus data. There is no way to make the change to ise the loyalty bonus first
