11-08-2022 12:56 PM - last edited on 11-08-2022 01:40 PM by computergeek541
Hi there, I pressed on YES button by mistake. I don't need any add-on service. How can I cancel it? I logged in my account and do not see this active yet. But, I'm afraid they may charge my card for $40 in December. I do not want that to happen. Please help. Thank you.
11-08-2022 11:25 PM
Thanks. I do not see that message you highlighted in your screenshot. I guess the plan change is not triggered.
11-08-2022 02:16 PM
You are not seeing the important part. You need to scroll down to see the potential plan change. If you see it but decided not to go through you can cancel the change.
11-08-2022 01:38 PM
Thanks much for your prompt response everyone. This is what I see when I logged in.
11-08-2022 01:03 PM
HI @alexthomascv When you are at that Change plan page, you should see something like this
just press Cancel Plan change
11-08-2022 01:02 PM
@alexthomascv Follow @hTideGnow instructions.. if you can log in.. no need to message a CS agent
11-08-2022 12:59 PM
HI @alexthomascv this is not an add-on but a plan change.
but you can stop it. Just login to My Account, go to Plan & add-on, click Change My Plan, you should see a notice saying you have a scheduled plan change , just click Cancel
11-08-2022 12:59 PM - edited 11-08-2022 01:10 PM
This is NOT add-on.
You just changed your plan to $40/15GB data plan.
You can try to talk to agent and explain your mistake. Maybe even through web site you might be able to reverse plan change.
- Send a private message to the CSA - agent by clicking Here
No need to talk to agent. Cancel plan change could be done trough your account. Thanks guys!
